Zenith B2 carb identification
tvscum
Hello,
This came off a 1926 Gotfredson farm truck but may not be stock.
Zenith B2 carb (tractor carb?). Trying to identify a rebuild kit and new air mixture screw part number.
Photos here:
http://s82.photobucket.com/user/tvscum/library/Zenith B2 Carb
Thanks
The adjustment screw... It would not have had an oring, too old for that. There would have been a graphite
packing under the gland nut. Tighten the nut to squeeze the packing, did 2 jobs, kept it from leaking, and
kept enough resistance to keep the needle from turning once set. You might find some graphite washers at a
better hardware store, on the aisle with all the little drawers full of life saving nicknacks! Or possibly a
plumbing supply that deals with saving old fixtures.
Thanks! I found an adjustment screw here:
http://www.external_link/ABC564-zenith-main-jet-adjusting-needle-assembly--fits-many-brands--models
I will take your advice about a graphite washer. Looks like I need a float too. :(
thanks! FYI, I think the unidentified carb above is similar to a Zenith model # 11629. I found a new adjustment screw online.
Zenith Main Jet Adjusting Needle Assembly
I needed a float too! :(
That is a similar carb to the ones used on allis ca's. I shopped all around and found the best deals on amazon.com. They have floats also as well as carb kits
