perryjosh64
Folks my Ford 2000 will run fine at times and others randomly just shut down as if it's run out gas but got plenty in tank. Today it happened while I was mowing a pasture. I let it sit for awhile then it crank right back up, run fine for a awhile then do it all over again. happened 3-4 times so I just gave up and parked it. The sediment bowl is inline with the carburetor and stays full. However it also appears I have another sediment bowl right below the fuel tank on right side (as your sitting the seat) with a shut off valve on it (will have to replace it as it leaks around the screw handle). there are a few rust spots in the tank but doesn't look to bad? I'm guessing either its flooding or I got something in my fuel line/carburetor? Any thoughts or advise?
