Ford 7000 steering help
WCFarms
New User
We removed the steering column to replace the seals in the hydraulic block/ column assembly etc. Now I'm trying to install it back into housing on the tractor (worm style gear) and having trouble with all the ball bearings. Does anyone have any tricks or know the way to do this. we've tried grease etc....Thanks in advance!!
Figured it out, pretty easy really.....Need to install the steering shaft first with the bearings, 8 fit in the tube, and then put the block and cap on top, wheel etc. Can't do it with the steering assembly and shaft installed together...
