Ford 641 transmission gasket/seal
cledford
New User
Hello all. I am in the process of a clutch change and noticed an oil leak from the transmission. Is there supposed to be a gasket on the pictured part and is there supposed to be a gasket on the input shaft. Neither had a gasket when removed, Just silicone. Thanks
Not sure about the input shaft, but the cover you have pictured... Keep in mind that if you add a gasket, you
will decrease the preload on the bearing behind it. That said, since it was running without a gasket, I would
go back with no gasket and automotive silicone. Clean it well, it should hold.
wow.. uncover a bad repair, and suggest another bad repair, and then smear it up with blue glue.
gotta love some of the advice here....
