The tractor will not start when using the starter but does s
Doug57
New User
I have a Hinomoto E280 that will not start when using the starter but does start when pulled. Any ideals what the problem could be.
Thanks
Doug
West Monroe, LA
Check your cranking voltage to your starter when making a start. Your battery voltage may be too low for your ignition. Hal
Does the starter spin it normally? If it's slow, could be the starter bushings, bad connection, low battery, etc.
How healthy is the engine? Does it run normally once started? Low compression can cause starting problems.
How is the engine shut down? Does it have a stop solenoid? Is it staying actuated when the starter is engaged?
You're in West Monroe, La... Look up Mountain Man, bet he could fix it! LOL
I noticed you were from West Monroe, I am from Natchitoches and I wanted to invite you to a show. This won't help you with your problem with your tractor but it might take your mind off of it. I am a member of North Louisiana Vintage Tractor Club.
Antique Days of Ruston Festival
August 21-22, 2015
7th Annual Ruston Antique Tractor Pull and Show
Presented by
Boeuf River Antique Tractor Pullers
Branch 178
www.BRATP.NET
Branch 179
www.NLVTC.NET
„h Antique cars and trucks
„h Antique farm equipment
„h Vendors
„h Arts and crafts
„h Hit & miss engines
„h Working blacksmiths
„h Kiddie pedal tractor pull
„h Kiddie barrels, train rides
„h Women¡¦s skillet toss
„h Swap meet
$5.00 Admission (children 6 and under FREE)
For tractor pull: $10.00 sled hook fee
Drivers must have E.D.G.E.T.A. insurance
Contact information: Bill Little 318-381-6115
RV hook ups available at pull site
Contact Angela Manning, 318-243-4941
Hosting the South Central Regional EDGETA Show
North Louisiana Expo Center¡X5 miles north of I-20 on Highway 33
Other
Attractions
Saturday Schedule
Friday Schedule
Unload tractors
Practice pulls
Tractor games
6:00 EDGETA Dinner
8:00 Registration
9:00 Farm Stock Pulls
12:00 Lunch break
1:30 Competitive Pulls
Concessions will be open both Friday & Saturday
Special rates for Antique Festival at Comfort Inn, Days Inn, and Fairfield Inn
More information at our websites at www.bratp.net or www.nlvtc.net
7:00
Back 40
Blue Grass Music
Will try to make a show. However, I work for the Sheriff's Dept. Sometimes we have crazy hours.
Thanks for the invite!
The engine does sound normal, however,does have 2300 hours. Compression does sound very possible. Does M.M. have a number? Thanks for infor!
As previously stated we need to know the voltage between the starter's cast body and the starters pos post WHILE cranking.
