4020 John Deere clutch assembly
farmer64
New User
We have put in a new disc for ground clutch, new pto disc, prressure plate, had the fly machine back to specs, put the 3 pins in, all 3 new bearings, and we are having trouble, when we push the ground clutch down, then engage the pto we have back pressure on the ground clutch. It's hard to push. Any suggestions what to do now? Thanks
Your clutch finger height isn't correct from the sound
of it. There is a gauge for this but it is used with the
tractor split. Are the clutch arms all the same height?
They can be adjusted through the inspection cover in
the bottom of the clutch housing.id try trial and error
on them before splitting the tractor again. As long as
all the fingers for each disk are exactly the same
distance from the throw out bearing it should work
ok.
