Ford 800 12 volt wiring diagram
mfranklin601
New User
Hey Guys,
I need a wiring diagram for a Ford 800 tractor that was converted to 12 volts. The wiring job that was done on this tractor is a mess and I need help bad. Thanks in advance.
Go down to the Ford forum and ask or check the archives. Many have been posted over the years. I could explain it but I do not have a diagram
This diagram uses a Delco 10SI alternator (most common used) and a 12 volt coil you can get from NAPA for about $23 Part number IC14SB.
Hello,
I am now to this Forum. I have a Ford 881 S.O.S that I desperately need a 12V wiring diagram to repair/replace the wiring harness. So for I have not been able to find anything online. This Diagram is good but I have a 4 post rely. Also any tips would be helpful.
