I have a 1955 model 50 that has a new battery, volt regulator, new wiring and connectors. I have a good generator, with new brushes and a clean armature. If I equalize the field once started and running, it charges just fine. The problem is I must do this EACH TIME I start up the tractor and run the thing after it's been shut off. I do not disconnect the battery.
I am beginning to think the generator just isn't putting out as much as it used to.
Any help or suggestions?
