leveling control arm won,t move
mildbill
New User
Leveling control arm won,t move
seems that after replacing pump cylinder was replaced the pin that is in the arm going to hyd. Pump is hitting cylander housing
not allowing operation of intake and exhaust ports
Hard for us to be able to help you help your self with out a lot more info like what tractor is it etc
Is your control arm bent? It should never need to move forward enough for the pin to hit the cylinder.
(quoted from post at 17:36:58 07/15/15) Looks straightto me if anything looks like its leaning off center towatds cylender
didn't mean bent left/right, I meant bent fore/aft.
