willie in mn
Ok, I see the reasoning for chaining the 3 pt when using the hyd of an N tractor to
operate a loader. The question is, would it work by just letting the 3 pt raise to top?
Maybe letting it raise, then stuff a wood block under the lift arms?
Dangerous as it might be, I just had a thought. Could blow the end off the internal lift cylinder before lifting the loader. Is the end of the cylinder a weak spot?
Tnx
Willie
Tnx
Willie
