BUSHNELLMAN
I am intending on buying a ford 8N and I want to adapt a front end loader from another tractor on it... my dumb question is this Since the 8 has a 3 point hitch then it has hydraulics correct? If that is the case does this tractor have a place I can hook into the hydraulic system to run the front loader's hydraulics? If I am correct is it difficult to find said connection point?
If that isn't the case where/ how can I hook up and run a hydraulic pump on this tractor... I think I've seen the pump mounted on the front and it looks as if it runs off the fan pulley
THANKS! I may seem a little slow but I've never been this old before!
