broke ex valve
opiegm29
New User
Chaged it out still sounds like a hammer hit
metal when I turn it over. Spits out gas from
carb like valves anit working right. Did I break
something inside like governor parts. K181
kohler 1967
Shouldn't have hurt the governor.
Where did the broken valve go?
Did it get on top of the piston? Could have broken the piston skirt.
Between the intake valve and the head? Bent the valve, causing the spitting out the carb.
Everything on top is ok. The sound is coming when the push rod is going down there is a slight pause then a hard metal to metal sound. I know I,m goi to open it up just wondering what to look for.
