IH 275 AUGER
IH27512Acres
New User
I have a INTERNATIONAL Windrower that has a disintegrated bearing on the top Auger that is causing the support rod to move back and forth along with the sprocket. this causes the chain to slip of the auger, because the sprocket is drawn inward.
I want to place new bearings on the support rod but cant get the auger support fingers off the rod because the rod is lager at the end then on most of the rod.
How do I do this
