GlassOfGasoline
New User
I disassembled the hystatic transmission. There's a few things that caught my attention. First there is a pin that locks the thingamajingus the pedal moves to actuate fowardnreversenand speed. That is really loose. I can imagine putting a better fitting pin in there to remove as much slop as possible. Making the pedal movement assy tighter. Also there is a pump and a motor. They are built and sold as a whole. im not sure what the tolerance is supposed to be. I'm getting (motor).677in (cylinder).678out(piston).....(pump)cylinder .6315 piston .6295. These can't be bad can they?
