Wiring for Leader D
Trying to wire Leader D tractor. I can not find a wiring diagram. It has a on off switch and starter button and solenoid for starter. Positive ground. I have neg to solenoid from there to neg post on amp meter. Other post goes to starter. Small post to starter button. I have 6 volts to amp, switch, and to starter button, but when I hit starter button I lose the voltage, new solenoid, no voltage to energize solenoid to engage starter. What am I doing wrong.
The wiring sounds correct.
Try putting your tester directly across the battery posts, try the starter. If the voltage drops off the battery is low or bad.
If the volts stay up, start moving the test leads one connection at a time, trying the starter with each move until you find the voltage drop.
Steve, my problem was a bad ground cable, was not getting a good positive ground. Once I got that solenoid would click. Up and running. Thank you for your reply.
