JD 25555 interior
sandel
Cab interior is trashed out in JD 2555. Any suggestions on best place to source new cab kit? Anyone done a similar replacement and if so what observations or advice?
I"ve done a couple of Fehr Cab interiors, will do more. When you price various sources, check if adhesive is included. I take the seat out to get room to work, and use a wire brush on a 4 1/2 inch grinder to prep the surface. Vacuum the interior, fit the pieces. Adhesive is non-forgiving- you can"t slide the foam into position or readjust.
Test fit without adhesive first. Start in the corners under the seat that are partially hidden as you will get a wrinkle somewhere if you haven't installed one before.
