Friend has a 901 Ford that will start and run fine then suddenly either not start or miss terribly. 12 volt conversion with resister and 6 volt coil replaced with a new NAPA 12 volt. New condenser. Points look good and gapped at .025. Coil to distributor wire is metal and clean. Was out 2 days ago after my friend said it ran with a horrible miss. I checked the voltage to the distributor side of the coil when open and get 12.46. Coil primary read 3.8 ohms. Secondary 8,500. I thought I should get around 3-3.5 volts to the points when closed. I got 3.2 volts at the distributor (negative)side of the coil the first time I checked but subsequent checks were at .12 volts. Same with just a jumper to the coil +. I didn"t do anything except remove and reconnect the test probes. However the tractor started and ran fine for 2 hours pulling a disk. Parked it and restarted it a couple times no problem. Friend called this morning and says it won"t start.
Carb was rebuilt with a master kit. The shutoff switch on the gas tank will not close off the gas but fuel flows steadily when the line is disconnected. Advise?
