intrepid31
New User
Ok, I have a 1964 John Deere 1010U Tractor with the 540/1000 PTO. Here's my problem after a couple of hours of mowing the RPMs start bouncing from approx. 2200 to 1600. The tractor runs great before this and will run fine for about 30 to 45 minutes if I shut it down and let it sit 10 to 15 minutes after it starts acting up. If the tractor sits for a week then it will run fine for a couple of hours and then start acting up again. I have changed the cap, rotor, plugs and plug wires. The spark plugs are gapped correctly and are burning correctly (according to the plug burn page of my car manual). The temp gauge says that the tractor is only getting to about 170-175 degrees. I took the carb off last summer and cleaned and rebuilt it. I have also changed a the fluids and filters. I have not found any water in the fuel and as best as I can tell there does not seem to be any crud the fuel tank or system. BTW disengaging the PTO seems to have little or no effect on this issue.
thank you in advance for any ideas or help with this.
