farmall 130 is leaking fluid at the pump. I had just put a homemade scrape blade on the rear and it weighs about
100 lbs. I read somewhere on this site that the fast hitch is rated for 65 lbs . did the extra weight blow out a seal? and can I rebuild it using the repair kit # IHS3020. also will it bow out again using this much weight? thanks scott
