drmmartin64
this is a 2424 international tractor already 12 volt. the alternator would never charge. purchased a 63 amp 3 wire. new battery. I followed the schematics on hookup. light does not come on when keyed switch is turned to on. the alternator charges but the light never goes out when it is running. have a volt meter installed. my wiring is no 1 wire to light and then to ign. no 2 is attached to the alt post. S on starter solenoid wire hooked to solenoid terminal on ignition switch.. coil wire from ignition goes to R on starter solenoid then to plus side of coil. new starter swich my problem is the light is not working properly and worried it is not wired right. all help would be appreciated.
thanks.
denny martin
thanks.
denny martin
