4030 load control shaft issues
plfiremanc8
New User
I have a 4030 tractor with cab and 2 remotes that I had the load control shaft seals replaced on a while back, since the new seals were installed the 3 pt hitch only works in the lowest position on the draft control, the lift barely works now, I understand that it's possible the load control arm finger may have fell out that rides on the shaft, does anyone have any insight on how to repair this?
Thanks Joe
I removed the shaft and took a look, appears the finger has fell out of the arm, what is the best way to get the finger back in place?
(quoted from post at 06:10:10 05/01/15)
hat i don't know,...been a long time since i worked on a JD load shaft.
