Matthieu149
New User
Hi all!
I just got my Farmall super A 1952 splitted at the transmission. I need to replace the leaking seal front seal. While I am here, I thought I would replace all the bearing and gasket accessible from here to make sure leak stop and maybe reduce the noise of the transmission.
I am now stuck at removing the top gear shaft and bearings. Seal housing and clutch shaft have been removed. I also got the pin on that small gear at the back, for the reverse I think.
I cannot figure how to remove those bearing. There is no place for a puller, and I am afraid of damaging anything if a start tu pull an pry anywhere.
Could anyone give me an advice on how to dismantle this thing, I could not find anything online!
Thank you!
Thank you!
