I recently purchased a 1960 Farmall 560. In the process of cleaning up general leaks, and I replaced a gasket under a cover that in the book says it is in the place of a "seasonal disconnect"....directly behind the cover for the PTO driven gear in the TA portion of the case. On each side of this plate there is a hole that is about 1/2" in diameter. The hole on one side has the end of a pin/bolt visible. the other side was covered by oil/gunk, and I used a pick hook to clean it out. I can shove a screwdriver all the way up into the case from this hole, and I did pull some gunk with metal shavings out of it.
Can anyone tell me:
1. what it's for?
2, what should be in it?
3. Is oil from the case suppose to be free to come out of this hole? (it appears that it has been)
I should mention that this hole is not threaded, and the hole cannot be felt by my hand when the earlier mentioned cover is removed.
Any insight is appreciated!
Can anyone tell me:
1. what it's for?
