My PTO was always turning and could not be shut off. I did some work on it and now having trouble with the adjustment. It is the clutch type PTO, and it's the version that needs to be removed from the tractor to adjust. The main problem in there was I found deep grooves worn in the release sleeve by a bad release bearing. That has been replaced, but I'm having trouble getting the clutch pack adjusted. On the bench I snugged the spider up to the clutches, then tried to adjust the spider tension as the manual suggests. But I cannot distinguish a over center "snap" as the manual says. I've loosened the spider way up and still cannot feel this "snap". I've had others look at it and no one feel the snap. Can anyone help as to what I should see at the roller under the pressure plate, or what I should feel.
I am new at this, and the last thing I want to do is try it and burn the clutch pack up right away.
I appreciate all suggestions, Thanks!
