Water in oil
I just picked up a 550 oliver that has water in oil. It's gray slime. They guy I got it from just got it and changed the oil, got it started and shut it off and noticed the problem. He didn't want to mess with it. I would like to fix it if possible but won't know until I get it apart. What if anything can I use to rinse the inside of engine before it's taken apart?
Don't bother. It's most likely the O-rings in the bottom of the sleeves. They're wet sleeves,so when you get them out,you won't have any problem at all cleaning everything out with a hose or pressure washer. When they're out of there everything is opened up wide open.
