930 fuel sender
Had fuel tank off my 930 for about a month. This old mind did not take note or make a note of which direction the
fuel sender float sets in the tank. Is it toward front or rear of tractor tank?
It will probably only go one way that will allow the float arm to swing without hitting the end or side of the tank. Just hold it above the tank and swing the arm, see which way it needs to go without hitting anything.
