I am looking for help with this tractor.
The problem is when I go to start it the starter gear grinds against the gear on the flywheel. Both the small gear and the gear on the flywheel are very worn.
My question is can those two gears be flipped around?
In order to do this I need to remove the flywheel, how do I do that? The flywheel does not have the two clamping bolts like the service manual says it should. If I remember correctly my dad replaced the flywheels years ago, (I was a teenagers then and didn't watch or help him do it) My dad is gone now so no asking him.
Doing research I have found that it has a compression sleeve on the crank shaft. I have no idea how to remove the flywheel to flip the gear around
Any help would be appreciated
