installed new float, needle valve & seat.
adjusted float many times, engine starts quickly, runs great at lower RPM, no gas leak from carb w/engine off- Problem- when move throttle to approx 3/4 RPM or above, need to pull choke out at least 1/2 way for engine to run smoothly. higher the RPM, more choke needed. thanks in advance for suggestions
