Buckbuster69
New User
Hey guys,
I have a bush hog I am wanting to replace the PTO drive shaft because the one on it is old and who ever had it had the wrong size for the mower. This issue I have is I bought a new PTO shaft but both ends have the 1 3/8 x 6 spline on it and the mower where the gear box is has a coupler attachment with a sheer pin in it. I took it off and that is when I found out it didn't have the 6 spline to slide the new shaft on. What do I need to do? can you buy a shaft that has the 6 spline quick connect on one end (tractor end) and a coupler with sheer pin connection already on the gear box end. Or could someone just swap out the u-joint that has that connection for the gear box end? please help, I need to do some tractor work tomorrow and the weekend.
thanks,
Marc
thanks,
Marc
