Removing the throttle lever from 1955, TO35
dwaldro
I'm trying to remove the dash from my TO35. Got all gauges loose but the throttle lever and adjustments are so rusted up, I can't determine the best way to remove the throttle lever. I've read one post that suggested loosening the friction disk assembly and lowering it but I still can't determine how the lever comes out of the adjustment linkage. All help is greatly appreciated. Thanks, D.Waldrop in MS
mine is rusted apart on one end. But I believe the end connected to the friction wheel slides back to release it from the little ball joint on the friction wheel.
Thanks for the info. I got it off and that was the way I got it. Take the cotter pin out and back off on the adjusment and it slips right off the "pin". Taking the 55 model apart is a challenge but "ain't" it fun?
(quoted from post at 18:01:45 03/18/15) Thanks for the info. I got it off and that was the way I got it. Take the cotter pin out and back off on the adjusment and it slips right off the "pin". Taking the 55 model apart is a challenge but "ain't" it fun?
ot as much fun as using it. I have a few things that need to be fixed on mine still but I have to get finished using it first. The more I use it the more I need it. Soon though....
