Juicybusa2
Have a light duty land pride utv with a 20 hp Honda GX 620. Intermittently it just clicks and won't start. Battery is good. Will start if I jump terminals on the solenoid. Normally I would just say the solenoid is bad but when it clicks and there is no start, the dash mounted voltmeter shows less than 12 volts even though the battery shows 12.5 or so when checked directly. So in short even though the battery is good 12.5, intermittently the voltmeter is less than 12 volts and no start unless I jump the solenoid. All connections clean and tight. Solenoid or something else? Thanks
