john connell
I've been repairing a 1737 Uniloader from the early '70's, during the last year. I Completely drained the hyd.system replacing the dirty fluid with new. Instead of using ATF I opted to fill with a universal tractor hydraulic/transmission fluid simply because of cost, I got a good price on it and the fact that I use this fluid in my tractors all the time without any problems that I'm aware of. My mechanical repair was all good with the exception of the hyd. system. It is very slow to operate at all, especially when cold as it is now. The fluid is foamy and I've bled lots of air out. The system sat entirely empty for quite a long time and I wonder if something crawled inside one of the lines or maybe the filter or a major line is somehow blocked (dead mouse maybe). The system operated fine before being drained, and now hardly at all - struggles to lift the arms even 6 inches. Is this a fluid issue? Is the viscosity or consistency so far off that it won't work? Perhaps the pump isn't compatible with the fluid or could the pump go bad while sitting so long? Anybody have any ideas as to what should be the next step in solving this problem. Your advice is much appreciated. Thanks in advance for your thoughts. John
