I have owned a TD 6 crawler for nearly 15 years. I tried to start the gas engine side recently after the crawler had sat for over two years in the weather. No luck! I have replaced points, distributor, etc. and have good spark at the plugs. Fuel is getting to the carburetor via gravity feet. Intake is drawing air when cranking but the engine does not even cough when ether is applied.
I have a 1000 cranking amp battery and have force-started the dozer directly on diesel without going through the gas side. This is quite and effort. After running on diesel for a while, I attempted to convert back to gas but no go. Anyone have any ideas about what might be going on. As far as I can tell, I have checked spark, fuel and air.
