tractornewbie
New User
I had a mechcanic work on my tractor and he said he had to shim the flywheel and not to drive or use the tractor it could brake the flywheel or crank (said theres a wobble to it) and its a 2,500.00 dollar fix. Got the tractor back and held the shaft end of a micrometer against the block and the point next to side of flywheel and turned over by hand. It was good except about 2 or 3 inches it moved in from point so held a straight bar stationary from block to tire in front of flywheel and that had some wobble from front to back but don't understand how you can fix that without turning it on a lathe. I'm new at this so could someone explain what he means. I drove the tractor at his house before loading it and it runs great and feels smooth also couldn't see any shims in splines so figuring they must be very small.
