will ZETOR 8011 injector pump fit LONG 910 tractor
i currently have a long 910 and fuel is leaking out of my injector pump where the shaft from the throttle linkage protrudes from the outside of the pump opposite the throttle linkage...i am looking to replace the injector pump if i am not able to stop the leak, and after some web searching i came across a similar injector pump for a Zetor 8011 that looks similar to my existing pump,and knowing that my 4 cylinder engine is built by zetor i am wondering if the pump from a Zetor 8011 will bolt up and function correctly on my Long 910 tractor
any input is greatly appreciated
thanks,Tractor_mike1260
I don't know about your exact question but I had one on an AC175 leaking at throttle shaft and shutoff shaft. Leaking so bad i got air in system. My tractor was running fine, I had new seals put through out and reinstalled it on the tractor and it is running fine now. You may want to check on getting new seals but in it. Mine was a CAV pump on a 4 cylinder Perkins engine.
Yes the pump off an 8011 will if a 900 and the 910 as they are in fact the same tractor. The 910 is a newer version of the 900 and both were built by Zetor and imported to the U.S.A. and painted blue and sold as Long. Bandit
Thanks for the quick replies
The replacement pump that I found on eBay looks slightly
different and doesn't have the shaft coming through the
outside(away from engine) toward rear of pump like mine does
My pump is like the pic that someone posted above and here is
a pic of the replacement pump from eBay look closely you can
notice small differences
You could contact the seller and ask for a shot of the back side of the injector pump to see if its a newer version of the pump. It may a newer design and have the throttle adjustment moved to the other side? Hard to say.
Have you been keeping motor oil level checked in the injector pump? Fill level is checked by taking the bolt(with slot) on the side of the pump by the hand pump, The drain is on the bottom about and inch farther back than the one the side. If you have any questions just ask as I do have the books for a 900 and a 910. Sorry not the best picture. Bandit
How sure are you that the pump from Ebay is going to be good and not leak? I've had leaking pumps on Masseys and I send mine to Dieseltech who is on here. He is darned reasonable ( probably a lot cheaper than the pump you're looking at) and I've never heard of any problems with any that he's done. Just my thoughts and I don't get anything for recommending him. Keith
