tractor_mike1260
New User
i currently have a long 910 and fuel is leaking out of my injector pump where the shaft from the throttle linkage protrudes from the outside of the pump opposite the throttle linkage...i am looking to replace the injector pump if i am not able to stop the leak, and after some web searching i came across a similar injector pump for a Zetor 8011 that looks similar to my existing pump,and knowing that my 4 cylinder engine is built by zetor i am wondering if the pump from a Zetor 8011 will bolt up and function correctly on my Long 910 tractor
any input is greatly appreciated
thanks,Tractor_mike1260
