bluediamond1
New User
I'm trying to remove a hydraulic pump on a 1966 ford 4000. the tube above it is leaking and I can't get it off Can anyone help
Unless you add and after market device, your TO-20(and the TE-20 and TEA-20 and TO-30,Ford 2N and 9N that use this system) does not have position control. That is you cannot set the height of the implement and expect the three point control to hold that position. The Ferguson System was meant for ground engaging equipment(plows, discs, etc).
You can go to the Harry Ferguson Forum at this site or to fergusonenthusiasts.org for plans on how to make a simple position control device or you can buy a Zane Thang (Ford N site)to get position control on your TO-20.
