i am on the final stages of putting the engine back together on a case VAC, as i had to replace the camshaft. A Few issues
1) When putting back the Crankshaft, the parts Diagram is showing 3 parts that appear to go on AFTER the Crank gear (vt 3225) The parts diagram shows them as T 3220/VT3373 and VT3380, However, my son and I don't recall any parts that go In Between the Crank Gear and the pulley...possible these are really not necessary? I can email a diagram if needed.
2) Does anyone have a sequential list of things i need to do to get timing on track? Here is my understanding
a) Line up the Cam and Crank Markings
b) Turn the engine until the fly wheel markings line up
c) Get #1 cylinder to TDC
d) Adjust tappets to 1/16 inch ....go from Tappet to tappet by cranking engine
e) Install Distributor, and again, make sure #1 is TDC, and rotor is on #1
Any better suggestions?
