lanthony2020
Trying to remove shift knobs in order to replace torn shifter boots. These puppies are really on there. Not sure if they are screw on or press on. Can't see any threads.
Can you remove these without destroying them? Sprayed them with Liquid Wrench before heading home today.
On a side note, should I grease the tops of shaft bases as long as I am at it here? Thinking added protection?
Thank you in advance.
LN
LN
