lanthony2020
Hello, my JD 302A has one of these "Ether" ports. The person I purchased this tractor from, was under the impression that this dash "Ether" port, accepted some sort of "Ether Cartridge" or "Pill"?
After reviewing the parts manual for this, looks like it either accepts a special "Can" of ether or you just insert the ether pipe and spray?
Thought about retrofitting this with a spring loaded oil cap or tire stem/cap at manifold?
Any thoughts? Does this old system work OK?
Thank you in advance.
LN
LN
