Case 730 diesel tank
I would take it off, thoroughly clean it, inside and out, indent the spot, and then fit a 1/16" thick patch from flat stock and BRAZE it in place, and then grind and smooth the repair, and then paint.
Loren, the Acg.
how big is the hole ? ,, you might be able to use redcote by applying duct tape over hole and allowing curing time .OlGentdc
