lanthony2020
Hello, I have an injector that is leaking at the base of injector/head. Went to dealer, he provided me with a small plastic like O-ring. Purchased three as the other two injectors are damp around base as well. The front injector is leaking quite badly and running on manifold and down block.
Problem, easy enough to get at injectors, but how to pull the actual injector out of the head after you loosen and remove the bolt, unhook fuel line and return?
Anyone have experience with these. It is in my 302A.
Thank you in advance.
LN
LN
