I'm new to tractors but this problem only popped up after I pulled the right side hood off my FORD 901 Select-A-Speed to access the wiring - after the ignition wiring shorted and self-destructed.
Now after the tractor's ignition wiring has been replaced and the tractor's engine is running great. I find that the PRO cable will not budge. There are no obvious kinks in the PTO cable body but it will not pull out of push in.
Any help is diagnosing this new problem will be very much appreciated.
