Gilli
New User
Received new exhaust manifold gaskets for 9n. Which side (convex or concave) goes to the engine side or does it not matter? Second, should I use gasket sealer?
It does not matter which side you use. I wouldn't use sealer. Its
not a real big deal to get them sealed up if the parts are clean
and in good condition. The biggest deal is the manifold surface.
It needs to be good and flat. If you have a doubt have it planed.
Its not expensive and it will pretty much guarantee a good seal.
(quoted from post at 17:32:37 10/19/14) It does not matter which side you use. I wouldn't use sealer. Its
hank you. I did have the manifold resurfaced and cleaned the engine side good.
