D239 injector nozzles
rwn
New User
Just finished placing new pistons, rings, and cylinder sleeves in my International backhoe with d239 diesel. I'm stumped in replacing the injector nozzles. The rubber o ring around the nozzle refuses to slide into the injector sleeve. With oil and lube, the o ring slips out of its groove and slides up the nozzle shaft. Is there a special tool for reinstalling these nozzles? Any advise will be greatly appreciated.
Hi "RWN" Welcome to the form. You will probably get a better response if you ask this question on the Farmall-IHC form.
I have a IH 2500B with a 239 but do not know the answer to your question.
Andrew
