john deere 430s transmission
(quoted from post at 15:56:08 09/05/14) how much money and work is involved to overhaul the 430s transmission ?? Thanks
Depends on what is worn or broken? Which of the five versions of transmission is it ? Have you checked the ring and pinion?
haven't seen the tractor in person just pics this
is out of my field of knowledge just trying to get
ideas on high to low cost on fix, they did say the
grind is in all gears any help thanks,
also theres a 420w late version slant steer 5 spd
i could possibly get , that has clutch issue, what
might be the cost on that? thanks so much
Compared to a 4 speed with a transmission driven pto and a 5 speed with a transmission driven pto. The 5 speed with live pto is worth sorting through problems and using it .
It's mostly a matter of dissembling everything AFTER you obtain the service manual from the nice folks at 1-800-522-7448. Clean, inspect, all new bearings, new bushings and new seals. Then adjust all clearances.
If the ring and pinion is worn. On slant steer 420's, 430's,435's and 440. The HD R&P from a 1010 gasser prior to serial # 31,000 is a bolt in upgrade.
Setting up the ring gear and pinion is a nightmare without the Deere dummy set up gauge. It is quite time consuming with the set up gauge.
