International 350 Help
Makes click at start. Won't turn over. Batt completely chargers. Spark from negative side. Solenoid new and correct. One day last week I try to start it three times on succession and after the third time it started. Was starting fine before that.
Are you 6 or 12 volts. Make sure your connections to the starter are solid. Even more important if its 6 volts. I just had to change a battery cable on my M - didn't look line anything broken but no current through it.
What do you mean by (spark from negative side)? If something is sparking, you have a loose connection. Take care of that & it will start.
