Ken Kauffman
New User
I am restoring a 1948 Lauson horizontal shaft engine. I need a magneto coil for it--the rest of the magneto looks great.
Also I cannot find any information about the carburetor. It is a Zenith with a straight-through horizontal barrel. The choke and excelerator butterflies are vertical in the barrel. It actually looks a lot like Harley Davidson carbs except it has a float bowl below the barrel and the float is a perfect copper sphere the pushes up on the needle via a rocker shaft that is not attached at all to the float.
It may be Zenith 10AY5 or a 21OA5. I found those two listed as Zeniths that were used on 1948 TSC 703 engines.
Can anyone give me any information about a magneto coil and about this carburetor?
