Hi,
I'm wondering if anyone can give me any tips on which product to use on the inside of the gas tank on my 1938 'D' John Deere to adhere the specs of rust to the tank so they don't plug up the carb. It got so each time I started the tractor, it ran a little worse. It would spit and pop until finally it wouldn't start at all. I noticed the sediment bowl had quite a bit of crud in it and I cleaned the tank as best I could, but there is still some fine crud in there that I can't get out. I want to get this completed so I can see if this was my problem or if I need some magneto work. Any advise at all will be appreciated. Thanks.
