Rear end gear swap???
biker4jc
New User
Morning all. I've got a '57 Fore 850, and when changing the oil in the rear end found some chunks of gear. The housing is also cracked, just got the tractor and it came to me like that. Filled 'er with grease and she's been doing ok, but want to put some other gears in 'er over the winter. Will the gears from a NAA fit? I can get a set pretty reasonable ($10) so I thought it might be worth finding out. I don't care if the ratio is different.
Thanks in advance! :D
The two rear ends are very different. It is highly unlikely that they would swap. There were so many of them built that you should have no trouble getting one from a salvage yard.
